It is currently Sun Sep 14, 2025 6:47 am
 Post subject: Mandolin Geometry
PostPosted: Thu Mar 01, 2012 12:57 pm
First name: George
City: Seattle
Friends,
As noted in various other posts, I'm currently building my first mandolin. I've looked around and haven't found target numbers for the geometry between the neck, bridge/saddle, and strings. I'm at the point where I need to adjust the alignment and set of the neck and I could use some direction.
[Edited to add: This is a simple Army/Navy or campfire style mandolin, so while there is a very slight arch to the top it is basically flat.]
Here's where I'm at right now:
Neck angle = 2 degrees
Fingerboard thickness = .250
Saddle height = .63
When I lay a straightedge along the top of the unfretted fingerboard it hits just at the top of the saddle. If this were a guitar I'd have a good idea as to how I should proceed, but the mandolin is basically a foreign object to me. Am I in the ballpark? Way off the mark? Are there general numbers I should be aiming to hit? Your guidance would be greatly appreciated!
George :-)
 Post subject: Re: Mandolin Geometry
PostPosted: Thu Mar 01, 2012 1:49 pm
First name: Big
Last Name: Jim
Is that an adjustable Bridge/saddle ? If yes , then you are in great shape . When you work off the nut height above the frets at a proper distance and then adjust the bridge accordingly.
Maybe Chris O will pop in and sound off on this thread .
PostPosted: Thu Mar 01, 2012 2:21 pm
First name: George
City: Seattle
Right now I have a non-adjustable bridge/saddle. I could change that, of course.
George :-)
PostPosted: Thu Mar 01, 2012 3:05 pm
First name: Big
Last Name: Jim
I would say from my limited experience that with a set non adjustable bridge / saddle it would be done the same as a guitar in basic set up. I always use adjustable so I really cant answer with 100% sureness
PostPosted: Fri Mar 02, 2012 1:30 pm
George,
Steve Smith over at Cumberland Acoustic sets is necks on his 'Traveler' model (Army/Navey style) at 1 1/2 degrees and shoots for a 5/8" tall bridge. He uses his Cumberland Acoustic adjustable bridges that have been modified to have the feet shaved off for a shorter bridge with more contact area. He's sells them at a discount from the full blown CA patent bridges.
He said he used to use a steeper angle but the bridges would get too high, causing an excessive break angle and putting too much pressure on the top. He also had to use a fretboard wedge at higher angles.
Hope this helps out.. and do check out Steve's bridges.
Good luck, I've been doing some neck setting myself lately.
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Sat Mar 03, 2012 10:48 am
First name: George
City: Seattle
Chris,
Thanks for the info. That's just what I needed to know. I'll go check out the Cumberland Acoustic site now.
George :-)
